Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
7. Schritt
Once all the adhesive has been separated, remove the home button from the front panel.
  • Once all the adhesive has been separated, remove the home button from the front panel.
  • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
  • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
Wenn der ganze Kleber entfernt ist, kannst du den Home Button vom Display entfernen.
Wenn du ein zerbrochenes Display austauschst, können Glasscherben am Home Button kleben bleiben. Entferne diese vorsichtig, bevor du den Home Button auf das neue Display überträgst.
[* black] Once all the adhesive has been separated, remove the home button from the front panel.
[* icon_note] If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
[* icon_reminder] Your replacement part may come with an [https://d3nevzfk7ii3be.cloudfront.net/igi/RBplrTYSIZiU3VDU|extra Phillips screw|new_window=true] already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
