Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from inside the rim. Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
  • Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from inside the rim.
  • Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
  • It is easier to start removing the tire from the rim around the location of the valve.
Hier Übersetzung einfügen
