Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from the inside of the rim. Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
  • Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from the inside of the rim.
  • Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
  • It is easier to start removing the tire from the rim near the location of the valve.
Hier Übersetzung einfügen
