Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
The speaker is located behind the inner back case.  Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
  • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
Hier Übersetzung einfügen
