Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
7. Schritt
Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps. To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
  • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
Hier Übersetzung einfügen
