Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Turn the logic board assembly over to access the heat sink's x-clamp. To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
  • Turn the logic board assembly over to access the heat sink's x-clamp.
  • To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
  • Starting at the front left corner of the x-clamp, insert a 1.5 mm flathead screwdriver between the heat sink's peg and the x-clamp's hook.
  • Gently rotate the screwdriver counterclockwise, releasing the x-clamp's hook from the peg.
  • The logic board is very sensitive to impact and scratching. Be sure to not let the screwdriver slip and damage the logic board.
Hier Übersetzung einfügen
