Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 9
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you. Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
  • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
  • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
  • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Hier Übersetzung einfügen
