Zum Hauptinhalt wechseln
Englisch
Deutsch
3. Schritt
Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
Push tube off the one-way valve
  • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
Mit einem Pkastiköffner kannst du den Schlauch vom Ventil abschieben. ( Wenn er zu fest sitzt kannst du mit einem Metallspatel den Schlauch lösen)
