Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using the larger plastic opening tool, gently push the tubing off of the one-way valve located in the center. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
Remove first tubing from one-way valve
  • Using the larger plastic opening tool, gently push the tubing off of the one-way valve located in the center. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  • The piece will remain attached to the center plate for now.
Mit einem großen Plastiköffner kannst du vorsichtig den Schlauch vom Ventil abschieben. (Wenn er zu fest sitzt kannst du einen Metallspatel benutzen)
Das Teil bleibt zunächst an der Hauptplatte dran.
