Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
Using the larger plastic opening tool, gently push the tubing off of the valve located on the side. (If the tubing is being stubborn and won't come off, run the Spudger tool around the inside of tubing to free it up.)
Remove second tubing from hose
  • Using the larger plastic opening tool, gently push the tubing off of the valve located on the side. (If the tubing is being stubborn and won't come off, run the Spudger tool around the inside of tubing to free it up.)
Mit einem großen Plastiköffner kannst du vorsichtig den Schlauch vom Ventil auf der Seite abschieben. (Wenn er zu fest sitzt kannst du einen Metallspatel benutzen)
