Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board. Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board. Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board.
  • Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board.
Verwende ein schmales Hebelwerkzeug aus Plastik, um die Stecker der beiden Flachbandkabel an der Unterseite der oberen Platine zu entfernen.
