Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Remove the front and back plastic panels.  2 plastic slides hold the panels to the toaster.  Slide the panels straight down, towards the toaster bottom. Note: the front panel is held on with several wires.  The wires have enough slack to remove the panel.  Do not put excessive force on the wires or they may break at the connections inside the toaster. Locate the 4 tabs at the top corners of the toaster.
A First Look Inside
  • Remove the front and back plastic panels. 2 plastic slides hold the panels to the toaster. Slide the panels straight down, towards the toaster bottom.
  • Note: the front panel is held on with several wires. The wires have enough slack to remove the panel. Do not put excessive force on the wires or they may break at the connections inside the toaster.
  • Locate the 4 tabs at the top corners of the toaster.
  • Bend the 4 tabs downward with the needle nose pliers to match the tab marked in yellow. Take care to not over stress the tabs and break them off.
Hier Übersetzung einfügen
