Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
The latch mechanism contains: A ferromagnetic piece that the electromagnet holds An arm to close the power switch
Latch Mechanism and Strain Relief
  • The latch mechanism contains:
  • A ferromagnetic piece that the electromagnet holds
  • An arm to close the power switch
  • A spring to launch toast in a vertical direction
  • Note: The latch mechanism can be removed by further bending the sheet metal. This is not advised as it may be very difficult to bend the sheet metal back to its original position during reassembly.
  • Pieces of electrical insulation board hold the wires. The heating elements are directly riveted to the boards and the boards are riveted to the sheet metal frame.
  • The strain relief can be removed by undoing 2 screws (blue). The screws have a special head type. They can be gripped with small needle nose pliers or wire cutters.
  • The strain relief cover comes straight off once the screws are removed
Hier Übersetzung einfügen
