Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board. Remove the speaker from the logic board. Remove the speaker from the logic board.
  • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
  • Remove the speaker from the logic board.
Benutze das flache Ende eines Spudgers, um die Verbindung des Lautsprechers vorsichtig aus dem Sockel auf dem Logic Board zu heben.
Entferne nun den Lautsprecher vom Logic Board.
