Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
The charging port is a square piece at the bottom center of the phone that is sticking out.
  • The charging port is a square piece at the bottom center of the phone that is sticking out.
  • If it is is loose simply remove it.
  • If it is still attached you must remove the charging port using the heat pen on your soldering station on top of the charging port until it becomes loose.
  • Gently remove the charging port using tweezers.
  • At this point you can solder the new charging port.
Hier Übersetzung einfügen
