Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
For safety precautions, it is advise that you remove the batteries before trying to remove and replace your tape cassette. If you're using an AC adapter remove it from the label maker. If using both, do both steps to turn off your label maker. If you're using an AC adapter remove it from the label maker. If using both, do both steps to turn off your label maker.
Removing batteries or AC adapter.
  • For safety precautions, it is advise that you remove the batteries before trying to remove and replace your tape cassette.
  • If you're using an AC adapter remove it from the label maker. If using both, do both steps to turn off your label maker.
Hier Übersetzung einfügen
