Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
4. Schritt
Now, that you have inserted the tape, place the batteries back. Make sure they are in the proper direction and place in tightly. Close the label maker, press the power button and is now ready for use. If your using an AC adapter or both batteries/AC adapter, make sure the AC adapter is plugged into the AC outlet. Then place correctly and push in fully to plug-in on top corner on device. Also, check that your batteries are place in correctly, if using both. If your using an AC adapter or both batteries/AC adapter, make sure the AC adapter is plugged into the AC outlet. Then place correctly and push in fully to plug-in on top corner on device. Also, check that your batteries are place in correctly, if using both.
Evaluating
  • Now, that you have inserted the tape, place the batteries back. Make sure they are in the proper direction and place in tightly. Close the label maker, press the power button and is now ready for use.
  • If your using an AC adapter or both batteries/AC adapter, make sure the AC adapter is plugged into the AC outlet. Then place correctly and push in fully to plug-in on top corner on device. Also, check that your batteries are place in correctly, if using both.
Hier Übersetzung einfügen
