Englisch
Deutsch
3. Schritt
Once you remove the back plate, you will have access to the area where the keyboard is located, so you could use the guide "How to replace the Keyboard" to remove it. Three more screws need to be removed to be able to lift the keyboard. Also, you will have to remove the small metal plate on top of the black connector with the red and black cables.
Remove screws holding keyboard
  • Once you remove the back plate, you will have access to the area where the keyboard is located, so you could use the guide "How to replace the Keyboard" to remove it.
  • Three more screws need to be removed to be able to lift the keyboard.
  • Also, you will have to remove the small metal plate on top of the black connector with the red and black cables.
Hier Übersetzung einfügen
