Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
5. Schritt
Lift the D-pad backing out of its compartment on the front case. The D-pad remains below the front case.
  • Lift the D-pad backing out of its compartment on the front case.
  • The D-pad remains below the front case.
  • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
  • The backing is slotted to its compartment to ensure that it will always be aligned properly.
Hier Übersetzung einfügen
