Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
  • Remove the seven Phillips screws securing the metal display tray to the rear panel. They may be very tight; watch carefully to make sure you don't strip them.
  • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
Hier Übersetzung einfügen
