Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
Using the larger plastic opening tool, gently push the tubing off of the second one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of the tubing to free it up.) Using the larger plastic opening tool, gently push the tubing off of the second one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of the tubing to free it up.)
Remove second tubing from hose
  • Using the larger plastic opening tool, gently push the tubing off of the second one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of the tubing to free it up.)
Mit einem großen Plastiköffner kannst du vorsichtig den Schlauch vom Ventil auf der Seite abschieben. (Wenn er zu fest sitzt kannst du einen Metallspatel benutzen)
