Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 4
Remove each wire by gripping with pliers and then gently pulling straight up. If you're having a hard time getting the wires off, gently wiggle the wire end back and forth with the pliers while keeping sufficient downward force on the circuit board with your finger. The wire should pop off easily. If you're having a hard time getting the wires off, gently wiggle the wire end back and forth with the pliers while keeping sufficient downward force on the circuit board with your finger. The wire should pop off easily.
Remove wires.
  • Remove each wire by gripping with pliers and then gently pulling straight up.
  • If you're having a hard time getting the wires off, gently wiggle the wire end back and forth with the pliers while keeping sufficient downward force on the circuit board with your finger. The wire should pop off easily.
Fasse jedes der Kabel mit einer Zange an und ziehe die Kabel ab.
Wenn das nicht leicht geht halte mit einem Finger dagegen und wackele mit der Zange hin und her.
