Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Remove the black protective piece of plastic by sliding it upwards. Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides. A center 3.5mm Torx screw will be covered by "VOID" sticker.
  • Remove the black protective piece of plastic by sliding it upwards.
  • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
  • A center 3.5mm Torx screw will be covered by "VOID" sticker.
  • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
  • Remove the protective panel by sliding it upwards.
Hier Übersetzung einfügen
