Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Wedge the flat end of a spudger inbetween the battery and the front panel assembly. Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly. If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
  • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
  • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
  • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
Hier Übersetzung einfügen
