Englisch
Deutsch
7. Schritt
If you are going to be using a screen assembly with a pre-installed frame, you may stop here and follow the previous steps in reverse with your new screen assembly. Otherwise, you will now transfer the LCD bezel as well as the speaker grille. Remove the metal tape to reveal the ribbon cables connected to the screen The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
  • If you are going to be using a screen assembly with a pre-installed frame, you may stop here and follow the previous steps in reverse with your new screen assembly. Otherwise, you will now transfer the LCD bezel as well as the speaker grille.
  • Remove the metal tape to reveal the ribbon cables connected to the screen
  • The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
  • Be careful when removing the metal tape. We can reuse it after we replace the screen
Hier Übersetzung einfügen
