Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
Next you will remove the upper two cables on the left hand side of the light engine, which plug in to the DMD board. First, remove the upper silver ribbon cable. Press in on the top and bottom of cable end to release the small clips that hold it in the plug. Then remove the second cable by pressing on the clip that holds the white cable end in to the plug and pulling it straight out at the same time.
  • Next you will remove the upper two cables on the left hand side of the light engine, which plug in to the DMD board.
  • First, remove the upper silver ribbon cable. Press in on the top and bottom of cable end to release the small clips that hold it in the plug.
  • Then remove the second cable by pressing on the clip that holds the white cable end in to the plug and pulling it straight out at the same time.
Hier Übersetzung einfügen
