Schritt 21 übersetzen
Schritt 21
Turn the DMD board over and you will see the DLP chip.
If you've ever removed a computer CPU you will find this is a bit different. The chip is not held in with a "Zero Insertion Force" mechanism with a clip or lever. Instead, it is held in by the tension of the pins alone.
Therefore, when removing the chip, simply pull up until it releases from the board.
