Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
To remove the camera you must first remove one screw that is holding it in place. You will need the phillips #0 screwdriver to complete this step Next you must detach the ribbon connected to the camera. To do this use the pry tool to gently lift the tape out of place Next use the pry tool to lift the rest of the camera off of the platform
Remove the Camera
  • To remove the camera you must first remove one screw that is holding it in place. You will need the phillips #0 screwdriver to complete this step
  • Next you must detach the ribbon connected to the camera. To do this use the pry tool to gently lift the tape out of place
  • Next use the pry tool to lift the rest of the camera off of the platform
Hier Übersetzung einfügen
