Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
The headphone jack is located on the bottom of the rear outer casing,  near the battery compartment. Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
  • The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
  • Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
Die Ohrhörerbuchse findest du am unteren Ende des Gehäuserückteils, in der Nähe des Batteriefachs.
Die Buchse ist mit zwei Kreuzschlitzschrauben #00 befestigt. Drehe sie heraus.
