Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
The case needs to be separated. Use your fingers or a pry tool to gently start at the front and work around the entire case. There are several cables connecting both sides of the case internally, so be gentle. The cables will be removed in the next step.
  • The case needs to be separated. Use your fingers or a pry tool to gently start at the front and work around the entire case.
  • There are several cables connecting both sides of the case internally, so be gentle. The cables will be removed in the next step.
Hier Übersetzung einfügen
