Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4
Remove the internal cables by starting with those in the front and working towards the back. Use your fingers to gently remove the cables from their sockets. The cables connecting the display to the main chassis are difficult to pull out using your fingers. A tool of some sort (tweezers in this case) may need to be used.
  • Remove the internal cables by starting with those in the front and working towards the back.
  • Use your fingers to gently remove the cables from their sockets.
  • The cables connecting the display to the main chassis are difficult to pull out using your fingers. A tool of some sort (tweezers in this case) may need to be used.
  • There is one cable that connects the display to the chassis. Don't pull on it. It has no impact on the display. It is highlighted in step 9.
Hier Übersetzung einfügen
