Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits. Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Pull the tab parallel to the face of the logic board.
Immer wenn du in der Nähe des Logic Boards arbeitetest, solltest du den Akku abklemmen, um Kurzschlüsse zu vermeiden.
Fasse die Plastiklasche an, die am Verbinder des Akkus angebracht ist, und ziehe sie in Richtung Vorderkante des Geräts.
Ziehe dabei parallel zur Oberfläche des Logic Boards.
