Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 17 übersetzen
17. Schritt
Handle the logic board assembly by its edges only. Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
  • Handle the logic board assembly by its edges only.
  • Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
    • Note that you'll be removing the logic board and DC-in board together.
  • Carefully pull the ports and DC-In board away from the side of the upper case and remove the logic board assembly, minding any cables that may get caught.
Hier Übersetzung einfügen
