Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 16 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Remove the top cover.
  • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
Hebe die obere Abdeckung von der Hinterkante und drehe sie in Richtung der Vorderseite der PS3.
Entferne die obere Abdeckung.
[* black] Lift the top cover from its rear edge and rotate it toward the front of the PS3.
[* black] Remove the top cover.
[* black] There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
