Zum Hauptinhalt wechseln
Englisch
Deutsch
5. Schritt
Before removing motherboard, we have to remove LCD screen. You can see more details on Samsung Galaxy Note 4 LCD screen replacement. If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way. If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way.
  • Before removing motherboard, we have to remove LCD screen. You can see more details on Samsung Galaxy Note 4 LCD screen replacement.
  • If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way.
Bevor du die Hauptplatine entfernen kannst musst du erst das LCD ausbauen. Mehr hier: Samsung Galaxy Note 4 LCD Austausch.
Wenn du allerdings nur die Rückkamera entfernen willst brauchst du das LCD nicht auszubauen. Es genügt eine Schraube links auf der Hauptplatine heraus zu drehen und die Flachbandkabel mit einem Spudger zu lösen. Denke dran, dass die beiden Kabel auf der Rückseite der Platine zum LCD führen. So ist das Risiko das LCD zu beschädigen geringer.
