Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 48 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
29. Schritt
Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
  • Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
  • Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
  • Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
  • You can try these alternate removal methods to reduce your chance of cracking the LCD during the removal process:
  • Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
  • Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Versuche nicht das LCD ganz zu entfernen. Es ist weiterhin mit dem iPad durch verschiedene Kabel am Ende mit dem Home Button verbunden. Hebe es nur am Ende mit der Frontkamera an.
Schiebe das flache Ende des Spukgers unter das LCD zwischen LCD und Abschirmblech, und hebe es vorsichtig an.
[* icon_note] Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
[* black] Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
[* icon_caution] Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
[* icon_caution] Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
[* icon_note] You can try these alternate removal methods to reduce your chance of cracking the LCD during the removal process:
[* black] Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
[* black] Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
