Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 12
Cut the adhesive under the flex and between headphone jack and midframe. And then pry up the sensors gently and remove the assembly finally. Cut the adhesive under the flex and between headphone jack and midframe. And then pry up the sensors gently and remove the assembly finally. Cut the adhesive under the flex and between headphone jack and midframe. And then pry up the sensors gently and remove the assembly finally.
Remove headphone jack
  • Cut the adhesive under the flex and between headphone jack and midframe. And then pry up the sensors gently and remove the assembly finally.
Schneide den Kleber unter dem Flachbandkabel und zwischen Kopfhörerbuchse und Mittelrahmen. Hebel dann vorsichtig die Sensoren hoch und entferne die Baugruppe.
