Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 7
Prepare bungees as shown in the picture with a loop on one side and a knot on the other side. The loop should just be big enough to fit over your riser and not fall off. Put the loop around the bottom of the riser as shown in the 2nd picture.
Brake handle bungee installation - Part 1
  • Prepare bungees as shown in the picture with a loop on one side and a knot on the other side.
  • The loop should just be big enough to fit over your riser and not fall off.
  • Put the loop around the bottom of the riser as shown in the 2nd picture.
  • Do not pull the open end of the bungee through the loop at the bottom of the riser - the open end should come out to the 'outside' of the riser.
  • if it is the right riser, the bungee should come out on the right hand side of the riser if you are holding the riser as you would just put it to your carabiner
Hier Übersetzung einfügen
