Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly. Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display. Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
  • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
  • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Hier Übersetzung einfügen
