Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing. Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
Removing the Back Panel
  • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
  • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
  • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Hier Übersetzung einfügen
