Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2 übersetzen
Step 2
Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector. Do so for both of the wires attached to the motherboard. Now fully separate the motherboard from the control box casing.
  • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
  • Do so for both of the wires attached to the motherboard.
  • Now fully separate the motherboard from the control box casing.
Hier Übersetzung einfügen
