Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
To remove the factory head unit, you must position yourself on your back with your head behind the dash. Use a flashlight or headlamp and look up towards the area where the head unit sits.
  • To remove the factory head unit, you must position yourself on your back with your head behind the dash. Use a flashlight or headlamp and look up towards the area where the head unit sits.
  • Use a very short screwdriver to remove the two downward-facing Phillips screws that hold the head unit in place.
    • With enough light it is fairly easy to identify these two screws, since they have large, hex-shaped heads.
  • Be very careful when removing these screws, since the metal brackets behind the dash have sharp edges. You may wish to wear some sort of gloves to keep from scratching your hands.
Hier Übersetzung einfügen
