Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket. Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
  • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
Hebe den Verbinder des Digitizer-Kabels mit dem flachen Ende des Spudgers gerade aus seinem Sockel .
[* black] Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
[* icon_caution] Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
