Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2
Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side.  Metal inserts on the bottom side lock the keyboard in place  until they are slid up and out. Be careful not to scratch or chip the computer when prying.  If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool. There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
  • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
  • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
  • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
  • Flip the laptop over so the keyboard is visible.
  • Insert the spudger under the left side of the keyboard.
  • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
  • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
  • Carefully slide the keyboard up toward the screen and out of the case.
Versuche nicht, die Tastatur von unten hochzuhebeln. Sie ist mit Rasten links, oben und rechts befestigt. Metalleinsätze auf der Unterseite befestigen die Tastatur, sie müssen zum Entriegeln nach oben und heraus geschoben werden.
Achte darauf, den Computer beim Hebeln nicht zu verkratzen. Wenn du ein Plastikwerkzeug hast, das lang genug ist, um als Hebel verwendet zu werden, verwende dies anstelle eines Metallwerkzeugs.
Auf der Unterseite sind Flachbandkabel befestigt, achte darauf, dass du die Tastatur nicht mit zu viel Kraft löst, da du diese sonst beschädigen könntest.
Drehe das Notebook so, dass die Tastatur sichtbar ist.
Setze den Spudger unter die linke Seite der Tastatur.
Hebe die Seite der Tastatur vorsichtig an, und ziehe kräftig an der linken Ecke der Tastatur, bis sie sich herauslöst.
Fahre jetzt mit den Fingern unter die Kanten der Tastatur von links nach rechts an der Oberkante entlang , um die restlichen Rasten zu lösen.
Schiebe die Taster vorsichtig nach oben in Richtung Bildschirm und entferne sie aus dem Gehäuse.
