Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 17
The circle pad consists of a small, donut-ish PCB with traces, a backing plate, and the spring-loaded X-Y sliders. The X-Y sliders each have two metal contacts that are always touching the PCB. As you move the sliders up/down and left/right, the metal contacts are adjusting the resistance of the circuit on the PCB.
  • The circle pad consists of a small, donut-ish PCB with traces, a backing plate, and the spring-loaded X-Y sliders.
  • The X-Y sliders each have two metal contacts that are always touching the PCB.
  • As you move the sliders up/down and left/right, the metal contacts are adjusting the resistance of the circuit on the PCB.
  • This, in turn, is registered as movement in whatever game you're playing.
  • Regarding the spring-loaded sliders: A spring inside the mechanism makes the "stick" always return to center. If you wanted to convert the circle pad to more of a "throttle" type joystick — where it doesn't return to center automatically — all you would have to do is take the circle pad apart and remove the spring found within.
  • This precarious conversion should only be undertaken by the truly dedicated among us.
Hier Übersetzung einfügen
