Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Locate the small notch on the bottom right side of the phone. To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off. The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  • Locate the small notch on the bottom right side of the phone.
  • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
  • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
Hier Übersetzung einfügen
