Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Due to the construction of the 4th generation Touch, the digitizer cable cannot be disconnected until the logic board is removed. Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable. Also, the display data cable is very short and is connected to the logic board near the top of the front panel assembly. If it does not become disconnected while freeing the top edge of the front panel assembly, be sure to disconnect it with an iPod opening tool before rotating the front panel assembly out of the Touch.
  • Due to the construction of the 4th generation Touch, the digitizer cable cannot be disconnected until the logic board is removed. Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable.
  • Also, the display data cable is very short and is connected to the logic board near the top of the front panel assembly. If it does not become disconnected while freeing the top edge of the front panel assembly, be sure to disconnect it with an iPod opening tool before rotating the front panel assembly out of the Touch.
  • Carefully pull the top of the front panel assembly away from the adhesive holding it to the Touch, minding the short digitizer cable connecting the two components.
Der iPod 4. Generation ist so konstruiert, dass sich das Kabel zum Digitizer nicht lösen lässt, bevor das Logic Board ausgebaut ist. Sei deswegen sehr vorsichtig beim Hantieren der Fronteinheit, da sie immer noch mit dem Rest des iPod über das sehr empfindliche Touchscreen Kabel angeschlossen ist.
Dieses Kabel ist auch sehr kurz und ist am Logic Board oben an der Fronteinheit angeschlossen. Wenn es sich nicht löst, während du die Oberkante der Fronteinheit löst, dann musst du es mit einem iPod-Öffnungswerkzeug auslösen, bevor du die Fronteinheit vom iPod herausdrehen kannst.
Ziehe vorsichtig die Fronteinheit oben weg von der Klebeverbindung, die es am iPod befestigt. Denke dabei an das kurze Touchscreen Kabel, welches die beiden Bauteile verbindet.
