Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery. It is better to use a plastic card if you have one. Gently lift up the battery as you continue to separate the glue from the battery.
  • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
  • It is better to use a plastic card if you have one.
  • Gently lift up the battery as you continue to separate the glue from the battery.
  • Lift up just enough to see where the glue is, so that you don't bend the battery.
  • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
Hier Übersetzung einfügen
