Englisch
Deutsch
2. Schritt
Lift the hard drive and connector assembly straight off of the tray. For reassembly, note that the connector assembly has two small plastic posts that fit into alignment holes in the tray. Be sure to fit the posts into the holes.
  • Lift the hard drive and connector assembly straight off of the tray.
  • For reassembly, note that the connector assembly has two small plastic posts that fit into alignment holes in the tray. Be sure to fit the posts into the holes.
Hebe die Festplatte und den Stecker gerade nach oben, weg vom Festplatteneinschub.
Beachte beim Zusammenbau, dass der Stecker zwei kleine Plastiknasen hat. Diese müssen sich wieder in den zwei Aussparungen im Festplatteneinschub befinden.
