Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Use the spudger to push the USB port on the bottom of the device inward. Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end. The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Remove inner circuit from case shell
  • Use the spudger to push the USB port on the bottom of the device inward.
  • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
  • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Hier Übersetzung einfügen
